M O T Advisories
M O T Advisories
My 1996 sovereign has just passed its annual MOT test but with a few advisories. The most significant is movement in the rear wheel due to the universal joints in the drive shafts! There are grease nipples available and I intend to pump in grease. My question is how difficult is it to change the UJ,s and would it be advisable to do both sides?
Received 10,952 Likes
If a u-joint is worn to the point where there is free play no amount of grease will help. It's junk.
Personally, no, I would not arbitrarily replace the UJs on both shafts. In fact I wouldn't even arbitrarily replace both UJs on one shaft. Once the shaft is off the car is takes two seconds to tell if the UJs are bad so there's no sense in replacing a good one.....especally since many replacments are lower quality than what Jaguar originally installed.
And DO make sure the wheel movment isn't coming from a wheel bearing or worn hub fulcrums.
littlelic69 (02-05-2014)
The following 2 users liked this post by AllanG:
Doug (02-04-2014),
Whilst the car was still on the ramp I went under it with the tester. Whilst there was slight movement at the wheel when rocked(wheel held top and bottom) he was able to eliminate most by pushing on the outboard UJ. The inboard UJ did not seem to make much difference. I guess the outboard is the one to attack first - when and if ever it stops raining. Thanks for advice.
Hadn't considered that, Doug. I've always (well, at least ever since my first attempt) done 'em with both rear tires off the ground (or car) during tire rotation, so it is easy to rotate both sides. May have to add another jack in to raise the tire on the affected side...
mawheele
06-19-2015 02:56 PM
Frog
01-29-2013 07:50 AM
