Mag-alloy Valve Cover Corrosion Problem.
I think I've located the XJR I want, just have to make the final decision now.
Unusually, the valve cover is not too badly corroded but if I get that car I'd like to get it back to as-new, or modify it so the corrosion doesn't occur in the future.
I could get a new cover from Jaguar, would lacquering or having it properly prepared and painted stop the corrosion?
I could clean up the corrosion and have it plated, either chrome or nickel. Would the plating stop corrosion or would it still happen under the plating?
I believe electro-magnetic fields from the coils cause the corrosion, is there ant way to stop this?
Or does anyone have any other ideas that have worked successfully?
A few years ago I had an H22A-engined Honda Accord and obtained a carbon fibre valve cover for that, are replacement covers for the Jaguar available anywhere?
I had a similar problem with my old X300, particularly in some of the plug wells. I just ground out the oxidation back to bare metal, rubbed the rest of the cover down with wet & dry paper, etch primed and painted with heat resistant silver paint. The job was quite labour intensive but cost little in materials.....
It seemed to stand up well for over a year till I sold the car but cannot vouch for the extended longevity of the method !
Bill999 (05-13-2013)
I'd have one as long as it wasn't made from plastic. Aluminium, steel, carbon fibre would be fine.
Carbon fiber has to be bonded with something. It is, after all, a fiber formed by heating a polymer in a furnace until nothing but carbon remains. Typically bonded with epoxies, but can be formulated to withstand very high temp.
But I think a valve cover might cost more than a lot of our cars are worth, unless it was made as a high production item.
you obviously missed my sarcasm. But, it's CF or Kevlar(which starts as a plastic) bonded with epoxy (a polymer = plastic), covered in a clear coat (urethane = plastic), so yeah, it's a lot of plastic..LOL.
One of the members said he filled the defects with a metal filled epoxy, then used high temp primer and engine paint from the local auto store (dupli-color). It held up for a couple of years before needing a re- spray. I don't think there is anything that is truly permanent, and at least that's inexpensive.
That was posted in one of the threads last fall.
mgb4tim (05-15-2013)
The cam cover NBC2564CA (up to VIN 116205 and NBC2564CB (from VIN 116206) are no longer avaliable from Jaguar. There is a new for sale on ebay (UK) for £99. Reasonable condition second hand ones are for sale at £50-£60 and are probably still cheaper than having them preofessional reconditioned.
Bill999 (05-18-2013)
