Mina Gallery Air Intake
The Mina short ram air intake, along with Andys bracket were the first two things I upgraded on my 95 X300. Unfortunately, I hadn't really been driving her long enough to give an accurate documented measurement of the improvement. I've sometimes wondered if I removed either or both after using my x300 as a daily drive for eight years if I could mark a notable reduction in performance?
So without qualification and a lack of dynamo testing, I can offer that I think Andy's Bracket makes the car feel a lot more lively and the Mina intake makes her feel like she reves up a lot easier (Breaths Better), Could be wrong but I think the intake also gives the engine a slightly different note.
Are these performance improvements a placebo post me mucking around with things that didn't need mucking around with? No Idea.
I also added a stainless guard around the top of the cone filter to help direct the cooler air from underneath into the intake. This gives the set-up a nice finish, its performance enhancement is 0, to be honest. Another plus is I now use a K&N air filter that can be cleaned and re-oil to save on the cost of replacement filters.
I'm getting a little away from the question but I've found the best performance enhancement you can do is to keep your jag well serviced. Clean air filter, throttle body, MAF good plugs, etc etc.
This is the Mina intake without the K&N filter and Gaurd
Ashton Dimovski (03-14-2022)
I have a Vanden Plas, so while I’m definitely interested in getting her to run more efficiently, aka the Andy Bracket and better breathing, I’m not too concerned with outright speed. She’s pretty lively to begin with because of that inline six…but I mean that said…who doesn’t want to faster? 😜
I like the idea with the metal guard — that would help out dramatically. 😃
The following 2 users liked this post by Keesh:
Ashton Dimovski (03-24-2022),
MikeyB10 (03-21-2022)
