my 97 super charger doesnt sound like the videos
Maybe I should record it and post it if I can. Ive now done two standing starts. ac off, trac off, trans in sport. 1st I shoved my foot in it and it broke loose just long enough to drift sideways a bit. 2nd time it shuddered a bit from standstill but no tire slip. I have very wide aggressive tires for the factory rim though. 0-60 seemed ok. didnt time it. Highway accel from 60-? is remarkably strong. However, my supercharger whine is not as loud as those Ive heard in videos. I have a stock airbox. Maybe thats the reason but there is a prominent whistle that the whine may get as loud as and thats it. I have no experience with these smaller blowers so I have no idea what they should sound like.
The car has new steering put in it and only seems to have cranky shock bushings I soaked to shut up. It really is a solid car. And I am extremely pleased with it. In a few weeks since I bought it, I have repaired faulty seat controls, abs wiring, cruise control vacuum, wiper relays stereo tweeters and station buttons etc. Its got a pretty nice coat of emron on it and zero door dings or rust. I am very happy. I am just looking to see if the above sounds a little soft on the power. I have read of this model breaking the tires lose at shift points. I have ordered the andy bracket and am seriously considering the lower blower pulley along with some intercooling improvement. I will go see how much the local speed shop wants for a dyno. If its in reason I will do one between each mod.
My SC is remarkably quiet. I do hear it at higher RPM a bit though, and I have the stock airbox setup as well.
At least yours will "break the tires free". Mine will not do that at all right now. I'm visiting a recommended indy Jag shop in Greensboro, NC in a few hours for a general going over and will see if there are some minor tweaks to get off-the-line response back where it is supposed to be.
I performed a 10 minute adjustment of the throttle cables and that already made a world of difference. So I suspect something like that is the culprit as the car runs great.
Mine pulls like a train at highway speeds though. Accelerating from 60+ is effortless.
Received 10,879 Likes
Jaguar made sure the noise was muted.
Just so I could enjoy hearing 'something' I bought a used (dirt cheap) XJ6 air cleaner lid and drilled a series of 2" holes in it. Now there's a pleasant growl. I saved the original lid in case I or the next owner wants to return to silence. The XJR lid, by the way, has a larger intake tube.
Mine does, on the 1-2 shift.
But so much depends on the tires as some are much grippier than others ...and the air charge temperature. My XJR seems like a different car on 40ºF winter day versus a 90ºF summer day.
I think the intercooling improvements are almost mandatory with a pulley change.
I know of two guys who went with pulley changes and then reverted back to the stock pulley. Apparently the increased supercharger speed heats the air charge SO quickly that there's a great power increase for a single burst and then the power actually drops off quite a bit until the intercooler can catch up.
I added a fan to the intercooler radiator and a higher flow intercooler pump in hopes of adding some cooling margin. I don't know if anything was actually accomplished....never took any measurements. I did it on a 'can't hurt, might help' basis.
I enjoy the occasional burn out as much as the next guy, maybe more, but personally I'd recommend going easy here.
I had to replace my diff at just 75k and I'm pretty sure my driving habits had a lot to do with it.....as I didn't get an "R" version with the notion of driving around like I had a bowl of goldfish on the seat
I think the Jag diff is only marginally capable of absorbing punishment.
My jag was not running for past couple of month and i will be happy to do some adjustments myself.
![Lightbulb](https://www.jaguarforums.com/forum/images/icons/icon3.gif)
Or you can just undo the adjusters and slowly adjust them until the play is gone and engine idle just barely creeps up, then back them off a bit. That's the 10-minute adjustment
Al:
Just did a quick throttle cable adjust of the tensioners. Ie... engine running twist til it revs a bit and back off a touch. Quick drive and it def moves the travel closer to you. Standing start test... some side drift on take off but absolutely no way this cars gonna chirp on a gear change. So I wondered if the sport shift select is working. It changes the shift point a few mph up the dial but I dont see that it does anything else. Its certainly not any firmer. The shift from 1 to 2 under full throttle is turbine smooth. If the shift were firmer... maybe.
The trans might be a tad soft and the tires stickier than most. I wouldn't let the lack of barking the tires on the 1-2 shift convince me that something is actually wrong.
I'm on 225/60x16 tires with a 3.58 diff.....which might well explain why mine breaks the tires loose more easily. I've run this set-up for so many years that I forget that I made the changes. Sorry.
swaschka (06-13-2014)
JagBrian
09-21-2015 07:17 PM
