My gas cap blowing off when opening
Search for "Rochester Valve". They commonly fail an can be replaced with an AC Delco variant for about $20. The member who posted the writeup was so kind as to even list the exact part# for you. Replace sooner than later as that excess pressure puts undue stress on both the fuel pump and fuel tank.
Received my valve today. First thing that I noticed is the markings on the valve. Tank, canister and vacuum. The vacuum is pointed in the opposite direction from the OEM valve. I needed to replace the vacuum line with a slightly longer piece in order to reach around to the other side.
Did anyone else notice this or just put the valve on backwards? So far no problems!
hen555
09-07-2015 11:13 PM
