Is My Rear Differential Bad?
Hello All,
I just bought a 1995 xj6 with 112,000 miles. I've been reading posts concerning problems with the rear diff. I can't really tell if mine is bad or not. When I decelerate I can hear a faint but noticeable noise coming from the back. It's not a whine it's more like a faint rumble. Is the car supposed to be dead silent back there? If the diff is shot then is there a parts supplier that sells them?
Received 2,190 Likes
Yes its BAD,, BAD BOY,,, BAD BAD BAD, now go sit in the corner.....![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
it would more likely be one of the outer wheel bearings than the diff, but you have to diag on a lift with it running at speed to make the noise. and you listen with a stethoscope. Also may be able to check for freeplay and may show which side is if any is good or bad by feeling freeplay, and is a learned feel.
As Brutal says in his inimitable way, you have a problem, but it is fixable. If its the wheel bearings these are not too expensive, but the diff will cost quite a lot more. Best to get it checked out as Brutal says. Don't spend money on a hunch, it costs too much if you are wrong. The diffs are normally available as service-exchange items, at least they are here in the UK anyway. A huge amount then comes down to a large amount, but that's not much consolation is it ? I had a diff fail on a 1967 Mark 2 when I was particularly poor, (I'd spent all my spare cash on it). That thing really hurt, but now I cannot even remember the sum nearly 25 years later.
Life's Rich Pageant !
Received 10,871 Likes
I changed my own diff. Basically took a whole weekend. There's nothing very high tech about the job...just lots of wrenching. I just followed the steps in the manual. If your doing this in your garage without a hoist and something to lift the rear suspension sub-assembly back into place, a second set of hands will be very useful. Air tools are a plus as well, for certain steps, but not essential.
If you decide to do it yourself I'll post back with a few tips that might save you some time...and I'm sure othes will as well.
Wolfy
05-28-2024 08:06 AM
05, ba, bad, boy, diff, differential, differntial, frontier, jaguar, jaguarforums, nissan, noise, problems, rear, rumbling
