Mystery no start
So I parked our baby in the heated garage to fix a bunch of things she needed. Removed left headlight assembly to repair a broken bracket, Changed module under driver's non operable seat. Repaired clock and replaced lights in dash and radio. Installed new brakes all around. and replaced an outer tie rod end. Went to fire her up and she cranks but no start. WTF! So I spent 3 hours retracing my steps and plugged in the code reader. Threw a few codes regarding the O2 sensor but thats it. Opened the joint at the fuel rail and gave her a crank. Fuel sprayed out just fine. Swapped the horn relay with the relay on the opposite fuse box. Ignition I think. No go. Reading the forums I see that I should get a reading on the tach as engine spins. Nothing. Bad crank sensor? Didn't show up on code reader. Any thoughts?
So yea, engine cranks but no needle movement on tach. Picked up a new CKPS, 15 mins later after replacing it, engine fired right up.
....you know in 15 years of oodles of XJ40's, X300's, X308's and X400's ownership I've never once had a faulty crankshaft sensor....but reading the amount of issues these give X300's I think I'll be getting a spare![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
CPS failure on Pugs, Fords and Mercs have ALL given me problems breaking down when hot, as in when stuck in traffic and heat soak.
I had a Pug 206GTi that would die intermitantly almost at the same waypoint after a 40 minute drive, that took some finding as it didn't throw a code and would start up again after a 10 minute rest!
...these Jag CPS's appear to die when cooling down from a previous run and that's pretty much it, bizarre, but maybe that the best way to fail!?!
I'll just add a caveat to the above.
XJ40 and the XJ300 especially don't like being engine bay jet-washed when doing a full vehicle valet and can disable a car for hours, until 'something' dries out with seemlingly no amount of WD-40 helping. Will then restart and drive all OK..... I know from bitter experience!
...I'm wondering if the CPS is at fault and doesn't like being wetted...maybe something going on there?
months and never had an issue.
My recent CKPS outage, it hadn't rained in days and humidity was low. And when it does rain, it's rare in rains in the garage
This last CKPS outage occurred at the same a number of other unrelated outages: had to replace the BPU and the central locking system and rear trunk (boot) electrical release does not work.
The sequence of outage was: turn key, lights on dash but no crank condition. Replaced the BPU; now a crank, but no start (and no tach needle movement) condition. Replaced the CKPS and she now starts.
Next step, figure out the central locking issue.
I wash the engine bay every 3-4
My recent CKPS outage, it hadn't rained in days and humidity was low. And when it does rain, it's rare in rains in the garage![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
buzzysingh
11-21-2019 10:51 PM
