Need error code help PLEASE!! P0411
vacuum line / electrical line
C.
Received 2,192 Likes
Thank you all so much for your help Is this the 1 way check valve your refering to 1995 Jaguar Air Inject Check Valve :: Also any Idea where I might find it? ( have to learn somehow) I am supposed to drive 1600 mi round trip with it leaving in a few days. Will this hamper the trip or cause futher damage to the car if it turns out the air pump is BAD & needs replaced. Thanks again.
KarimPA
09-27-2015 08:46 AM
