Need female connector for CK position sensor
Recently while grabbing a cam cover at the local Pick n Pull, I thought a spare CKPS may com in handy.... and since I broke the locking tab on my first Andy bracket install, I just clipped the wire about 3" back after unbolting it. Sensor and all for $9-$13; can't remember exactly. Get the Row52" app and set up alerts - I seem to recall a PnP or two in the Chicago area.
From memory the connector is likley to be from the AMP econoseal range.
If you look at the electrical section of the service manual near the start there is a Connectors section that has illustrations of the different connectors that are used. Econseal connectors should be widely available at low cost. You can even buy the individual connector blades and small rubber plug seals where the cables enter the plug body.
Grant Francis (06-17-2016)
Grant Francis (06-20-2016)
scubayachts
10-27-2018 10:47 AM
Uncle Fishbits
US Western
06-17-2016 02:20 PM
Oceansidesurf
06-09-2016 02:58 AM
