Need help with Altenator wiring XJ6 1997
In the above pic the small terminal to the furthest right which happens to be the same after alternator installation is electrically isolated from case ground which for better alternator performance can be better than case ground
This matches the schematic but then schematic are not always correct
I myself get them confused and someone else can pipe in after awaile if I'm not correct
The purpose of the noise suppressor is to further ( after the diode package inside the alternator does the major amount ) to smooth out the rotating from the beginning AC signal to being more DC
To test if the suppressor is not working you would tune into an AM radio station and hear engine speed vering interference
vasey
12-03-2023 05:09 PM
Lady Penelope
07-08-2019 02:17 PM
