I have a 1996 XJ6 that is believed to be in anti theft mode. This had been after changing a fuel pump (which was not needed) and a fuel regulator. This has crippled me financially as I was also living in the vehicle at one point please help
There is a inertia / crash switch that can trip easily dropping out the fuel pump
It will always be on the car's right fwd of the right front door hinge
Following will be a pic for a right hand steering model with the gas pedal in the pic
This switch does not always reset so you can jumper the 2 white wires with a paper clip on the 3 wire connector
There is a fuse # 10 that controls the fuel pump relay and for this fuse to be powered the relay in the corner of the right heelboard fuse box must close on key rotation
You can swap the left engine bay fuse box relay for the righ heelboard fuse box relay
You can have the key in the run position with engine not started and the heelboard fuse box relay must click in your fingers on relay removal
The following pic will show the OBD 2 connector as this same fuse powers your OBD 2 reader
