Need Help identifying this noise
I have a "clicking" sound coming from my dashboard behind the center vents and the radio area. It is intermittent but loud and sounds like something trying to actuate or switch back and forth. I don't want to tear the dash apart without knowing what it is. Seems to do it a lot on startup and then usually subsides after driving awhile. I searched the forum and didn't find anything that seem relevant but, don't know what to ask. Anyone have experience or an idea what it might be? Something to do with the HYVAC system is my best guess so far.....
Received 13,509 Likes
Hi crvols,
My first guess would be that a control module or relay has become noisy or a relay may not be latching properly. For example, the Gearshift Interlock relay and the Keylock relay are mounted under the ski slope a little above and to the right of the gear selector lever. Several control modules are in the general vicinity you describe, like the Body Processor Module (BPM), mounted just to the right of the center console, as is the Air Conditioning Control Module (ACCM). Another possibility that comes to mind: could the cassette player be mistakenly trying to load a cassette?
There are diagrams shown the relay and control module locations in the Electrical Guide, which you can download at the link below, courtesy of Gus and his website, jagrepair.com.
1997 X300 Electrical Guide
Cheers,
Don
Cheers,
Don
93SB (02-21-2017)
Don B (03-02-2017)
Ordered a couple of switch's from England and installed. It was fairly straight forward except getting the rivets out was a pain. I won't go into why on a $55K car a $2 switch is riveted like a plane fuselage!) The new switch is smaller and I secured it with micro screws and nuts future removal. Just remove the switch and solder the wires to the new one. Thanks to Tcasmarcus for helping to identify this annoyance!
New micro switch installed.
Yes, I bought Y4T6Y-1884 (DIAL0050494) from Dial Electronics Ltd. In England. Contact them at: enquiries@buy-transistors.com they were about $15 for two with shipping. Since I bought two and one is all I need at present, if you want to send me a self addressed envelope I will give you my spare for the help you have provided. Just PM me if you are interested.
