Need help, screeching coming from engine?
Old 10-23-2011, 03:05 AM
Virgilson's Avatar
Default Need help, screeching coming from engine?
Hello, i'm new here, I am asking question for my dad who owns the car. Can anyone please help and maybe suggest what the problem might be. Did some research and found it may be the belt, belt tensior? dad asked around and they told me it can be water pump or fan belt?
here is a sound clip. on some day it gets really loud. happens usually in the morning and sometimes throughout the day.
thank you.
Engine Noise Jaguar - YouTube
Old 10-23-2011, 03:29 AM
Cadillac's Avatar
Mine did a similar noise as well. It turned out to be a replacement for brand new fan assembly . Both main fan and aux fan and prior to tackling this job we replaced pulley, belts too . That was excruciating because people looked at the car due to vacuum cleaner sound After all these works done then a smooth sailing
Old 10-23-2011, 05:19 AM
vdpnyc's Avatar
Not sure about that sound from an engine, but window-box air conditioners make that same sound when the fan makes slight contact with the surounding facade, in the case of air conditioners this is usually due to rust causing the metal to deform or bulge slightly - so rotate the fan by hand (with the car off for heaven's sake!) and check if it drags at all on the housing around the fan
Old 10-23-2011, 08:59 AM
Received 8,307 Likes on 5,013 Posts
First thing is that you need to post in the X300 section.
The crank damper has come apart. The rubber section has failed.
You need to replace it but I doubt you want a new one if you can still get one from the dealer.
I removed mine and sent it to 'damper doctor' but there are many companies that can rebuild the crank damper.
bob gauff
Old 10-23-2011, 02:40 PM
Virgilson's Avatar
thanks for all your input. And sorry for posting in the wrong section.
Old 10-24-2011, 03:49 AM
Cadillac's Avatar
I have moved it off to the proper area . Kudos to motorcarman , he just looks at the small iamge and see which is which lol
Old 11-06-2011, 01:49 PM
jhxj6's Avatar
I have the same sound coming from my car. Usually only on cold starts in the mornings and when I get out of work late in the night. It goes away as long as the car is accelerating but as soon as I'm back to idle it's there again until the motor heats up.
Is the crank damper similar to a harmonic balancer?
Old 11-06-2011, 08:22 PM
The crank damper IS the harmonic balancer.
bob gauff
Old 11-07-2011, 09:28 AM
jhxj6's Avatar
o ok. When I showed my mechanic the sound he told me to stop by soon and have the harmonic balancer checked. Thanks motorcarman
Old 11-07-2011, 10:17 AM
On_a_Jag's Avatar
Hold the camera still! Sounds like an African beat.
Thanks motorcarman, I learn every day here. I did not know balancers could be rebuilt. It wouldn't be much to ship one, is there a place you know of that does the best job?
Old 11-07-2011, 12:42 PM
I used a FLAT RATE box from USPS (good to 70 pounds??) and shipped it to damper doctor but there are several places that rebuild dampers.
bob gauff
BrentGardner
28
04-26-2024 03:08 AM
montypeek
09-06-2015 04:57 PM
niner nellie
09-01-2015 10:53 PM
SingBlueSilver
08-27-2015 02:20 PM
dpappyp
08-27-2015 06:31 AM
Quick Reply: Need help, screeching coming from engine?
