need some help with my front suspension upgrade 1996 XJR
al_roethlisberger (04-10-2015)
The Bilstein B6 "Heavy Duty" shocks are the direct replacements for the OEM "green" Bilstein shocks on the US X300 XJR.
They appear to still be available from Shock Warehouse:
Bilstein shocks and struts for cars and trucks - Shockwarehouse.com
24-185806 F4-BE5-6725-M0 Bilstein Jaguar XJR and 300
Old Part No: F4-BE5-6725-M0
24-067249 F4-BE3-6724-M0 Bilstein Jaguar XJR and 300
Old Part
Old Part
B4 are the "Touring Class" B6 are "Heavy Duty"
B4 are the "Touring Class" = Normal XJ6
B6 are "Heavy Duty" = XJR
I'm glad you are pleased with the poly bushes. I am in the process of fitting mine, I used the superflex ones. One question, did you use a large washer under the head of lower wishbone pivot bolt or just use the bolt head as a bearing surface for the polybush? I added a large washer on the other end under the tiebar to provide something round and smooth to turn against.
, but figured that the bolt head was big enough for the smaller rear bush. Now I am thinking should I re-assemble it as something round would probably be better?
Im really looking forward to trying it out but whilst I had the subframe off I decided to paint the body and discovered that the damper mountings need reparing, so more work first.
#32
DIY Front Spring Compressor
Search is your friend
https://www.jaguarforums.com/forum/x...8/#post1319028
https://www.jaguarforums.com/forum/x...5/#post1321001
#33
#34
The yellow ball is a aftermarket aluminum shifter knob for a Honda. I was unable to drill a hole in the ball bearing I bought. Everything worked very well. I used a thicker threaded rod (m22) and it was almost too big to fit but it did clear.
I still have it and will let it go for $75 shipped.
PayPal
PayPal
#35
Are the bushings quiet? I've just finished removing all the poly bushings the PO put in my XJS because it squeaked horribly over every imperfection. Drove me crazy.
I can't say as I noticed any difference in handling with everything back to OEM rubber, and the car is so much nicer to drive now that it's not creaking and groaning all the time.
