Newbie Pre Purch Jitters
Guest
Posts: n/a
Hello:
I am looking at a '95 XJ6 (Vanden Plas trim level) with 90k for $4800.
Before I pay for a PPI, do you have a link or any list of things I should watch for and generally key points of failure?
What are the strong points of these things? How reliable are they?
...my experience has only been with early 70's E-Types where the main thing I recall was that my buddy needed to keep two at all times...one for parts, etc.
Thanks very much!
SG
Thanks very much!
SG
Well I had a '95 base model for 10 years. Just sold it for $5200, 111,600 miles. Just bought an '02 XJ8 with 20500 miles to replace it.
The only thing that failed on that car in ten years was an A/C compressor and oil pressure sensor. Replaced quite a few stoplight, turn signal and taillight bulbs over the years. You might want to keep a few on hand. Had a couple of warped brake discs but I believe any car can have that problem.
These engines hold 8-1/2 quarts of oil so I usually went 5000 miles before changing it. I don't think it would use more than 1 quart of oil between changes.
I just hope my XJ8 is as reliable as the XJ6.
I have been a gearhead since I was 15 years old so I did my own oil, filter and antifreeze, changes. Also Hoses, belts and brake jobs.
Can't tell you what these kind of jobs cost at the dealers.
Guest
Posts: n/a
Thanks for that...it helps to know what you sold yours for!
I imagine this topic (people wanting to know if a given car is "good" or "bad") is a PIA for most Forum members...I am on a couple of other forums for specialty cars I own and I get tired of it myself...so I appreciate your info.
I will just take it to a good shop for PPI and go from there...
SG
SG
wannabebuyer
10-01-2015 12:34 PM
