No hot air from heater
Received 10,978 Likes
The plumbing for the heater has a dedicated electric coolant pump. They often fail. It's a fair guess that yours is on the blink.
It's been quite some time since I owned an X300 so details regarding the pump have faded from memory. However there is plenty of archived advice and discussion, I'm sure
Pump brushes tend to wear out and can be replaced. Also high on the probability list: Thermostat stuck open. Heater matrix clogged - back flush it with water hose pressure. Less common - Water valve stuck. Plenty written and pictured here on it. Don't neglect the TSB's posted by Motorcarman.
motorcarman (04-06-2020)
I changed the brush's and reasembled the motor. I connected to my power probe to test run and nothing, the circuit breaker triped on the power probe, so I guess a dead short. I took it apart and there was a smell of burning and a little smoke. I removed the diode to test it and it looks like it is fried. Anybody know what type of diode this is, it has EJ4 on it, but could not find much on the Net regarding it.
I also got a dead short when I tested the pigtail.
Ian
Ian
JessN16
12-07-2018 08:19 AM
