O2 sensor question
No. The orientation procedure is only to change if they are connected backwards, i.e. the upstream connector attached to the downstream sensor.
Replace them one at a time and you'll be fine.
Get the NTK sesnsors off Rockauto.com, that's the cheapest place I have found and the NTK are the OE sensors.
Scotlad (04-09-2017)
