O2 sensor question
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
My '97 VDP is up for inspection and I haven't been driving it much lately, so the drive cycles have not been completed in order for it to even be tested for emissions. (I also had electrical work done recently, so the battery was disconnected) So I obtained drive cycle info from a Jag mechanic and attempted to complete them. While running the cycles, the check engine light illuminated. After plugging in the code reader, I received the code "P1187 O2 Upstream Circuit Short". I have purchased a single OEM upstream O2 sensor to install, but do I need to replace both upstream sensors to mend the issue? That is assuming there are two upstream sensors. (there seems to be)
Thanks!
Thanks!
P1187 = "Variant Selection"
from "http://www.jaguar-online-club.de/obdii_fault_codes.0.html"
Here are the o2 sensor codes...
p0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
Circuit Malfunction p0142 O2 sensor (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3 )
p0144 O2 sensor Circuit High Voltage (Bank 1 Sensor 3)
p0145 O2 sensor (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected sensor (bank 1 3)
P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
p0154 O2 sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction ( Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
panagiotis (07-13-2015)
Received 12,932 Likes
The following 3 users liked this post by Don B:
SD96XJ6L,
I have merged all of your posts on this topic into your other thread to reduce confusion among those who are trying to help and to eliminate duplicate replies:
https://www.jaguarforums.com/forum/x...2-52-a-152987/
Cheers,
Don
Cheers,
Don
93SB (12-25-2015)
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
