OBD II now I'm confused
![Talking](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
exactly which scanner will work on a 1995 x300? I see a lot of conflicting information on-line. I only the see the xj6 mentioned once in the posted sticky about scanners. What do you guys use? I have a harbor frieght near me, plus sears and your standard array of auto parts stores. I would like to purchase one this weekend. Thanks for everyones help on my different posts the last couple of days. Scott
Received 2,190 Likes
Brutal is, of course, right. However, there are a number of different protocols used for OBDII communication. The X300 MY95 uses ISO 9141-2, so be sure your choice says it is compatible with that protocol. And buy from a reputable place, as in some one who will take it back if it does not work. You will find that a scanner that gives a chart or oscilloscope is most useful, but they are also more expensive, and usually require dragging out a laptop to interface.
someguywithajag (06-10-2015)
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
I bought my code scanner today. Took the car out for a spin after getting a new battery and stopped at sears. bought the Craftsman CanOBD2 model 87702. Says it works on all obd2 cars. It has Jaguar in the specific code menu. I can take it back if it does not work. Will give it a try in the morning, feeling lazy now. I'll let you guys know how successful it is. Thanks for all your help.
Goncalo Proenca
12-09-2023 04:00 PM
baskervillema
10-01-2015 06:43 PM
