Odometer illumination.
Removing the instrument cluster isnt a big job; 15 mins or so. Google for the procedure, but from memory 4 screws and 2 ribbon connectors to detach. Access to the bulbs is obvious thereafter, and I suspect that a blown bulb is all that is wrong. If it is the odometer unit, this is detachable from the cluster, and can be sourced separately.
Steve M (01-12-2019)
