Oil Catch Can
Old 12-29-2022 | 03:42 PM
Anbran's Avatar
Default Oil Catch Can
Has anyone had any experience in the use of an "oil catch can" on their crankcase ventilation system? They seem like a good idea...
Old 12-29-2022 | 03:57 PM
aholbro1's Avatar
DFieldsend has: https://www.jaguarforums.com/forum/x...-setup-165132/
Perhaps others, I remembered at least one post here with pics, this is the first one I came across in search. You may find others, if you look.
Old 12-29-2022 | 04:28 PM
skywarrior's Avatar
I was advised that the only engines benefiting from a " oil vapor catch can" are those with direct cylinder injection.
Old 12-30-2022 | 02:55 AM
Keesh's Avatar
You can buy the Jaguar oil separator(JLM20709) for about $50US. You then cut your existing hose, tie in the separator and run a small hose from the bottom to a can or whatever catchment device you like. You could even buy a used dipstick tube that has been modified (or modify your own) and then the liquid oil would just return to the sump.
The problem is not about oil consumption, rather that oil finds it's way into the intake and eventually coats and then hardens on the throttle disc causing all sorts of problems with idle and drivability.
Old 12-30-2022 | 07:00 AM
bjarnetv's Avatar
Britishparts sells the oil separator kit pretty cheap - i have bough it myself, but haven't tried fitting it yet.
it comes with the modified dipsstick.
https://www.britishparts.co.uk/class...ther-kit-p3814
Old 12-30-2022 | 08:06 PM
Vee's Avatar
Vee
The Jaguar separator is not really a good solution. Eventually that plastic egg contraption will split in two.
The catch can works well to keep my throttle butterfly plate clean.
Anbran (12-30-2022)
Vee
04-28-2023 12:42 PM
Ubad2
02-13-2021 02:12 AM
2007 Rick
08-19-2020 11:13 AM
Barry_Tucker
02-27-2018 07:52 AM
Quick Reply: Oil Catch Can
