Oil Drain Plug specs anyone??
hi, my oil pan is starting to strip, and I am either going to have to retap my oil pan, or change it out. I would rather tap it out, does anyone know the exact specs on the stock oem drain plug on the 96 xj6? I know its a 20mm, but I need the exact specs with length and width and all. I wanna know if I should go with a larger drain plug, but my mechanic says to find out the specs first. If anyone can help, I would gladly appriciate it, thanks
20mm X 2.5 is the thread size. You can get a rethread kit but it is a bit 'pricey' and you have to get the hole and threads perpendicular to the sealing face of the pan or the drain plug will be crooked and leak.
I have done this repair several times and I usually have to remove the gearbox dipstick tube for access.
bob gauff
bob gauff
This is pretty cool, I did not realize that a rethread kit was available.
It's very interesting also the regional colloquialisms.
2nd hand seems to be a phrase used on both sides of the pond.
2p = 2pence = 2c = 2cents.
Breaker is what us yanks call a junkyard/salvage yard/used parts dealer etc...
Throw in boot, bonnet, lorry and glove and a yank could get really lost. And if you are from the southern US, as I am, don't be offended. It's my understanding that we all come under the heading of Yank to the Brits. Personally I'm a hillbilly.![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
It's cool to come here and learn about jags and linguistics at the same time.
aholbro1
08-05-2021 05:02 AM
Gerard Radimaker
09-13-2015 10:33 AM
