Oil drip behind oil filter.
Noticed a spot under the xj6 today.
Driver's side of engine wet and small amount of oil on block below oil filter. It has been about 2,000 miles since the oil was changed and this just started.
I did not have time to get underneath and look up but the drip is coming from the rear of the filter area (filter feels dry).
Any ideas on what this could be?
P1400 code was present as well.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
Couple of things in that area.
Oil switch, on top of the oil filter housing, and easy to get at, NOT, and is a common issue now with age.
Being a 4ltr, you got an engine oil cooler,and the pipes for that thing are attached to the bottom of that same housing, and are sealed with an o/ring on each pipe. They also are getting common issues now.
Bucky83 (09-10-2014)
<p><p>Thanks Grant, hope I will have a chance to look at it this evening. Even though it is tight, is it possible for a backyard monkey to make the repair, right? I'll just make sure no women and children are around. :-)</p></p>
This photo with all the peripheral clutter of suspension out of the way could make it easier for you to work out where the drip could be coming from as you won't get this clear a view on your vehicle either from above or below:
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/95330-oil-drip-behind-oil-filter-x300-oil-sump-removed.jpg?amp;d=1410260546)
It could be as simple as a faulty seal on the Oil Filter. If not, there's several possibilities with the O Rings on the Oil Cooler Adaptor (item 1) to Bypass Connector (item 4):
![Oil drip behind oil filter.-x300-oil-filter.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/95331d1480973784t-oil-drip-behind-oil-filter-x300-oil-filter.jpg)
Received 10,952 Likes
Grant Francis (09-09-2014)
Thanks for all of the input on this!
Drip is from above, rear of the filter, which is why I didn't really see anything that could be the cause. Possibly a pin-hole or bad gaskget I guess would be first area to check. I used a Purolator "gold" filter on the last oil change FWIW. I will have to get a better look to truly locate the source and let you know.
The following 3 users liked this post by motorcarman:
OK, thanks again for everyone's input. I got home late (again) last night and had a chance to look at it from above and I was getting concerned when I could not see cooler lines but could clearly see the "boomerang". Now I feel better about what I saw after motorcarman's post. It is annoying but not dumping tons so I will proceed to fix her on Saturday.
Are the o-rings an odd size or special compound?
Grant Francis (09-15-2014)
aholbro1
08-05-2021 05:02 AM
BoarHawg
12-14-2015 12:21 PM
