Oil pressure periodically reads 0
Starting just this morning, the oil pressure warning light periodically lit while the gauge, which only ever reads half (or 4, straight up), dropped to 0. Then, after a moment or two, the light went out and the gauge went back to normal. I pulled over, waited about 5 minutes and checked the oil level which was full.
Is it fair to assume I have a failing oil pressure sensor/sender? Is this a common or known issue on X300s?
Is it a time consuming job to replace the sensor (assuming that's what it is)?
Thanks in advance,
Rhett
Thanks in advance,
Rhett
Rhett (02-24-2014)
