Outside mirror needs to change to decaf!
I'm having a problem with my drivers outside mirror on my '97 X300. It sometimes has a little shake! I can move it (using the mirror control)towards the car, and it seems to help a little. Is there an adjustment that can be made to it? The controls in the door panel work fine. It's just a little hard to see through. Any help out there, guys? Thanks-in-advance!
I have a friend who is a MASTER TECH @ the dealer and was told the following: "Unfortunately, it sounds like one of the motor links to your mirror glass has broken. There are two separate motors in the motor pack for each mirror. Each has a link, sort of like a ladder that that motors in and out to position the mirror. When one of these break the result is usually a mirror that wiggles. " He has gone on vacation and will verify this after he comes back....... I'll keep you informed.
Guy-Pierre Boucher
09-16-2015 05:55 PM
