Overflow tank not hot
Hello,
I just replaced my faulty thermostat in 1996 jaguar vdp, which was running at 156 degrees f. The new one runs at 194f. I checked the overflow tank and it is up to the top, but it is not hot at all, dipped my finger in and it is cold. This is after a one hour ride. Is this normal? Did the air not bleed out from the thermo change? It just does not seem right?
Received 2,263 Likes
This thread is something of a coincidence, as i used my x300 for an errand today traveling about 25 miles and on my return I noted that my coolant expansion tank was not the slightest bit hot, not even warm, but it has been rather cool here this week and I always get the impression that x300s run a little on the cool side.
Kevin
I've never checked my thermostat,but removed it once to flush and change the coolent , once the engine is started the temperature gauge does soon start to move but probably needs at least fifteen minutes or so before it settles down to its usual place which is just under the half way mark, it will fluctuate a bit but only under this point, I've never had it go higher even in traffic, hope I'm not tempting fate by just saying that!
Great! You will probably notice a smoother running engine and your fuel mileage should increase with a properly maintained engine temperature.
