P0159 - Searched but not found
This is a new one because I could not find it in a search. P0159 - Heated exhaust gas oxygen sensor circuit slow response (bank 2, Sensor 2). Based on the description, I assume this is an oxygen sensor. I did put two of them back in the car that was older because I thought it was an O2 sensor issue with my other codes. However, I replaced both upstream O2 sensors, and the code is telling me that it is a downstream sensor?
Pins 3 and 4
These pins on the O2 sensor side of the pigtail connector will be the heating element
Don't cross whole connector positions when hooking back up , so 1 connector at a time
There is a different wire color on pin 3 between the fwd and aft O2 sensor pairs
On the car side of the connector the wire colors will be for the aft sensors pin 3 Blue / Pink ( UK ) and pin 4 White / Green , and fwd sensors pin 3 Blue / Brown ( UN )
You have 3 other connectors to compare your resistance values against
Don B (02-28-2024)
Parker 7 (02-28-2024)
I don’t think there’s a learning curve to the sensors.
When did you last swap out the sensors? What brand did you use. (I’m assuming they were new). Did you swap out all 4?
You may want to check your ECU harness connection. If you are getting moisture (not uncommon) this can happen. I would definitely check for signs of corrosion or water at the ECU.
