P0411 corrected now i have a P0430
I just fixed all gaskets and a breather hose off the valve cover ( inch and a half gap in hose) and the air pump kicked on without a problem. So i use my engine reader to check for codes and the original P0411 code has been resolved but now i have a P0430 code. I'm guessing i'm going to need a new cat converter? or possibly an O2 sensor? any ideas
1997 Jaguar xj6
1997 Jaguar xj6
Received 10,871 Likes
Ahhhhh. P0430. The bane of an X300 owner's life. Well, mine, at least. :-)
Yes, possibly a bad cat converter but also could be.....
-Oxy sensor as you mentioned. With a live-date scan tool you can monitor the Oxy sensors
-Air leak, intake or exhaust. Possible cracked exhaust manifold....fairly common and usually not audible but cracked nevertheless
-Leaky air injector check valve
-Oxy sensor wiring/connector fault resulting in skewed reporting to the ECU
Others will chime in with more.
baskervillema
10-01-2015 06:43 PM
