P1775
P1775 indicates a possible transmission problem, JTIS 21 says read transmission codes, which a generic reader can not do.
I wonder if that is the correct code. Could the reader be in error? Even if the coils are new, there could be a problem with them. Lots of info here on coils if you use search. Also, are the plugs the recommended Champions?
I cleaned the throttle body about a month before this code popped up, replaced the coils & replaced plugs with the recommended plugs. I had driven the car about 40 miles that day, parked it & about 3 hours later, got into it & it seemed to be in what I guess is limp mode & stalled out a few times. It took a long time before the car would start again. ( about 45 minutes each time ) The last time it started, I was able to feather the gas legal to get the car back up to the posted speed limit to get it home & I parked it. Now it starts right up, but has that flutter in the exhaust & the other issues I named above. Other than the flutter, it seems to idle fine, but starts backfiring through the throttle body & any time you attempt to apply very much throttle.
Received 2,641 Likes
derek15301xjr
10-20-2015 07:39 PM
Ben Guzman
08-23-2012 02:23 PM
