Past 4000 RPM Breakup
Old 04-30-2018, 09:03 AM
Carp's Avatar
I will finally get a chance to try some of these ideas and work on the Jaguar today
Old 04-30-2018, 07:26 PM
Carp's Avatar
Wasn't the spark plugs or coils. Cleaned and lubed both plugs as mentioned. Swapped relays as mentioned. Checked vac line at fuel pressure reg as mentioned. All were good. Crank sensor had build up including a tiny piece of metal. Swapped it along with the other changes. Runs out perfect now. And NO, no trans issues or damage from anything.....lol.....revving in neutral....... Don't really care what the actual cause was but in my determination it was a dirty crankshaft position sensor
The following 4 users liked this post by Carp:
89 Jacobra (04-30-2018), Don B (04-30-2018), littlelic69 (05-03-2018), Scotlad (04-30-2018)
Old 04-30-2018, 08:28 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
The metal debris would mess up the flux lines from the reluctor teeth to the inductor sensor face . As the rotational speed increases the output wave form signal is indistinguishable to get a count per unit of time as it gets tighter . Good find .
Old 04-30-2018, 10:52 PM
89 Jacobra's Avatar
Received 1,190 Likes on 691 Posts
The Shrapnel, could definitely cause the issue, as Lady P says it has to have a clear signal.
Jack
Old 05-01-2018, 01:40 AM
Carp's Avatar
Did the sensor last but the minute I saw that it was dirty and had a tiny piece of what looked like "mechanics wire" stuck to it, I knew it had to be the culprit. Thanks everyone!
allenward
11-02-2016 12:43 PM
davpryce
01-06-2016 02:27 AM
lubalb
02-19-2012 10:22 PM
mr.xtype
01-07-2011 10:04 PM
03-18-2007 12:57 AM
Quick Reply: Past 4000 RPM Breakup
