Please Help - Another won't start thread
Old 12-10-2023, 12:12 PM
clubairth1's Avatar
Received 2,502 Likes on 1,960 Posts
Also note we have seen multiple times that a replacement alternator works fine but the car still shows errors.
I recommend getting your original alternator rebuilt if you can. Then zero worries about compatibility.
We all know how picky Jaguars are when it comes to electrical stuff!
Parker 7 (12-10-2023)
Old 12-10-2023, 01:42 PM
Parker 7's Avatar
Received 1,012 Likes on 848 Posts
At 110 K miles my brush wear was at half life
The brushes are Avail on their website
Old 12-15-2023, 11:38 AM
Big Amar's Avatar
Hello,
I managed to find a local tech that specialises in rebuilding Alternators and Starter Motors, He tested the Alternator on his test rig and confirmed there was no output. He then found that two major components had failed. (Plug broke upon dismantling) These have now been replaced and I reinstalled the alternator this morning. All working.
If anyone does require help getting there Alternator overhauled please fee free to contact me and I will assist as best as I can.
I have a few minor electrical problems which I am working through:
No Electric aerial
No wipers (They were working)
Bulb warning light is on when I put the lights on yet ALL Bulbs are working
No sound from stereo (Harman Kardon Audio System)
Old 12-15-2023, 08:39 PM
Parker 7's Avatar
My terminal screw on the brush / VR ears as yours was fused as well so I need a brush assembly so a heads up for others.
On the current sensors in the exterior light module give you the bulb out :
Too low a current from the 4 car corner 13 pin connector under the car getting corroded
To low a current from the lamp pinched end with the contact ears that can be spung back out
A lamp assemble back end can get corrosion as the wires enter the lamp assemble , EV - 1 connector type
The connectors are EV 1 series and you can cut a service wire length from a trunk dome light ( 2 ) and splice in
For the premium stereo there are 2 fuses in the left heelboard fuse box and one in the trunk
On the wipers there are 2 relays of the same part # as the headlight . fog . AC clutch and such that can be swapped , the wires can come loose from the column switch as there are some pics from others
Someone was able to replace the capacitor in the motor to get going again
QueenSuga
10-27-2021 03:15 AM
TheOne
06-15-2017 09:09 PM
His_Nibbs
11-11-2011 12:57 PM
jignesh111
03-24-2011 01:08 PM
Tania1
68
11-18-2010 11:15 AM
Quick Reply: Please Help - Another won't start thread
