Please help asap
Cheers,
Now you have to check the fans themselves and get a look at the relay module below the LH headlamps. For low speed the fans are powered in series, one after the other, for high speed the relay module switches them both to parallel. They run at full speed then. If one fan is open circuit, neither will run at low speed.
So low speed they run on six volts each, twelve volts on high.
Good luck!
Good luck!
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
Collector1
09-26-2015 05:28 PM
WTB[NorthEast]: 2004 Vanden Plas Headlight Assembly LH
European_Auto11558
09-25-2015 08:05 PM
