Potential Dodgy Boot/Trunk Wiring.
The plastic cover over the right hand boot hinge was damaged. I acquired a pair of replacements. On fitting it, it became apparent that it had been visited before. I stripped of the tape and lo and behold three wires had been repaired by inserting a two inch insert, properly soldered. I checked continuity from before the repair to the boot lamps. Both OK. Nevertheless, the lamps do not illuminate, although they are not open circuit. So my question is, where is the switch that causes the circuit to be completed?p
littlelic69 (05-05-2017)
