Power Assisted Brake Failure Possibly
Hello All,
Thanks In Advance For Any Help! A week ago Soldered the 2 pins inside the anti-lock / traction control module after getting C1095 code and both lights went out and put it all back together, I bleeded the lines and brakes worked perfectly for a week. Went to drive this morning and pedal is hard as a rock as if the brake power booster has failed. I can still stop car if I push real hard. However, obviously it is not safe to drive. Any help with this would be great. I am not sure what the issue is for sure or if maybe it is a common issue?
Martin
Martin
Snookfever (11-30-2016)
The following 2 users liked this post by 95Leaper:
motorcarman (12-01-2016),
You might be able to find something thru the Dorman (Help Parts) section in your local auto parts store or just grab one from your local salvage yard. As long as the fittings are the same on both ends they all work the same. They'll probably only charge you a dollar or two. New is probably about $10 using a Dorman part.
