POWER LOSS/SURGING AFTER WARM UP & UNDER LOAD - TACH STEADY w ERRATIC RPMs ON SCANNER
https://www.jaguarforums.com/forum/x...l-woes-171624/
When a DIYer tried to help me remove the fuel tank, a plastic buckle that joined a harnesses from the cabin to the trunk broke loose unnoticed, and this had cut off power or resulted in incomplete signals to ignite reaching the engine bay. Hope this is not your issue, but bare wires or poor ground are often the quiet suspects.
Betting on the CPS connector
I'm with countyjag....when I fitted my Andy Bracket, and replaced the CPS as a matter of prevention, I wasn't impressed with the flimsyness and fit of the connector...I'd definitely give it a good fettling...
