Power seats..revisited
brand new to me 96 xj6..seats non functioning. But there's a constant clicking emanating from under drivers seat and when seat controls are tried..nada, but when i press memory on door..i can hear motor attempt to engage, but no movement..passenger seat totally non responsive...
----UPDATE--- Ok, so upon further investigation i found and checked all fuses (good) apparently the clicking was from the door lighting relay driver side footwell..not the seat motor. as its virtually impossible to see under seats i cant tell whether connections are bad, but i doubt both seats wouldn't work simultaneously. But who knows. pried off side seat controls, checked connector..all good. any ideas from past experiences ? Thanks !!
Well, I just purchased a new/used XJ6L, and the seat did not work. Having tons of drivers modules I replaced it and it kind of worked. After further investigation, there are a few stripped gears, and the seat is basically kaput. I am now in the process of getting another seat, or at least trying to. I also found a few of the gears and will try to replace them. However, Jaguar did not make that too simple and will require a little metal cutting and welding to get it repaired.
Surfer-J
07-13-2009 06:46 PM
