power steering hose leaking on rack side
Gents. Top left and bottom left hose leaking through the fitting at rack end. Just pulled the line off, noticed there was no o ring or any such thing. Should there be something there or does the line just work without it? I have tightened the bugger up as tight as she will go but they still weep through the line between the brass fitting and the steel line.
Time for a new line, I guess, or am I missing an olive or o ring?
Thanks gents![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Peter
oh yeah, s3 xj6 (1980)
Thanks gents
Peter
Looks like it needs an "O" ring per Jaguar Service Technical Bulletin @ JagRepair.com
http://www.jagrepair.com/images/TSB/...fer%20Pipe.pdf
hugh ness (02-09-2016)
Thanks guys. I realised I probably stuffed you all up a bit. I was messing with both top left and bottom left and realise now they are quite different. So, the high pressure line (top) has an o ring and the low pressure one hasn't got one.
I bought a box of 420 imperial o rings from Aldi the other day. I guess it's fair to say something should fit it. Please don't tell me they are special o rings! LOL!
well, i really made a mess of it. bought high and low pressure hoses. low pressure worked ok. hi pressure was us version. about 1 foot too long and fittings didnt match pump. my pump end has originally a flared ending but what i got had an o ring and was quite different. anyway, i lucked out as i had another jag pump at home which fitted. changed it all over, discovered hose was way too long, and worst scenario, it still leaked through the new line at rack end. so either the new hose i bought is faulty or i should just push this thing over a cliff...
turbopower501
08-23-2016 09:54 AM
FS[Western US]: X300 XJ6 XJR Left Over Parts
XJsc-guy
01-12-2016 12:37 PM
FS[Western US]: XJ6 S3 Oil Cooler Hoses NEW
series1twelve
11-14-2015 10:56 PM
