Power steering issue
Welcome to the gordonreid2041,
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
gordonreid2041 (01-29-2015)
Received 13,255 Likes
Hi gordonreid2041,
Welcome to the Jaguar Forums!
The easiest way to bleed the steering system (per the Jaguar Workshop Manuals) is to start the engine and turn the steering wheel lock-to-lock, back and forth, several times, until all the air is bled out of the system by the normal function of the hydraulic system. Check the fluid level and top it up if necessary. That has always worked for me.
Cheers,
Don
littlelic69 (02-05-2015)
Dicque
09-19-2015 12:53 PM
