Power Steering leak
From the bottom of the reservoir where the 2 lines clamp , the hoses distort from the age and leak going everywhere.
Cut an inch off the hoses for new clamp / hose material
If the leak is coming from the steering rack you can do a drain refresh cycle 4 or 5 times to get fresh power steering fluid to rejuvenate the seals
It is a ZF 7852 series but I don't know about the last numbers as someone recently took a pic of their's
See attached file below
I actually added AT-205 leak sealer last week hoping it would help but that’s when it got worse. After reading a couple of threads on here I was contemplating buying a generic hose hit the low side and replacing that. But when I looked under and saw that drip I assumed that maybe it was coming from somewhere else.
In theory you can change the outer most gland nut seal ( without removing the rack ) as your open boot may have let dirt in to effect the seal
Someone ( 944play ) with the V - 12 went through sourcing the proper boots if yours can't be salvaged
Steering rack boots, ÜRO JLM11688 do not fit - Jaguar Forums - Jaguar Enthusiasts Forum
Yeah it's seems dry up top. It was pretty gunked up but i wiped down the hoses and their doesn't appear to be a fresh leak from the reservoir hoses. I took a closer look at the boot and there's a good amount of fluid in there. So it does appear that is the source of the leak. There's a couple of good youtube videos on rebuilding them so I'll have to check that out. Thanks again for your input.
Parker 7 (02-10-2024)
jaguarrick1
06-26-2020 03:47 PM
