Power Steering Pump Removal & Replacement
Old 09-18-2015, 01:27 PM
BigBossRadio's Avatar
Default Power Steering Pump Removal & Replacement
To replace the PAS Pump is it necessary to remove the pump and cone adapter as 1 piece or just the pump?
If so does anyone have guidence an the correct procedure.
Thanks for any help
VickTrader (12-08-2022)
Old 09-19-2015, 09:39 AM
Received 8,147 Likes on 4,915 Posts
All this and MORE in the large file download area That nobody can find????
I thought I just posted all these a few days ago??????
bob gauff
File Type: pdf
File Type: pdf
The following 5 users liked this post by motorcarman:
93SB (03-22-2022), Don B (09-22-2015), oldjaglover (01-21-2024), someguywithajag (02-26-2022), VickTrader (12-08-2022)
Old 09-19-2015, 11:34 AM
Thanks for the PDF's
I will take a close look at them again....... over the weekend.
Thanks for all your help
Old 09-22-2015, 09:18 AM
Received 13,104 Likes on 6,529 Posts
Bob,
The problem seems to be that neither the standard forum SEARCH or ADVANCED SEARCH functions find the files in the large download area, even if you search the exact title of the document. So unless members have some clue that the documents are available, they don't know to go looking for them. I'm hopeful that in the near future the forum tech gurus may be able to resolve this dilemma with expanded search capabilities.
I know I speak for all the other members when I express my gratitude for all the countless documents you have uploaded for our education and benefit.
THANK YOU!!!!
Don
The following 9 users liked this post by Don B:
93SB (03-22-2022), BigBossRadio (09-22-2015), Camaro69 (12-10-2015), oldjaglover (01-21-2024), RJ237 (09-22-2015), SKRTSKRTXJR6 (03-02-2022), someguywithajag (02-26-2022), Steve SOMERS (03-01-2022), VickTrader (12-08-2022) and 4 others liked this post. (Show less...)
Old 02-25-2022, 01:08 PM
oldjaglover's Avatar
bob gauff
I am trying to find the entire process of removing and replacing my PAS pump that I'm sure is leaking. The links you posted have nothing to do with the procedure itself. Each one is just a one page cover for an update or something, but no other information.
I trust your knowledge and experience implicitly, but my searches have resulted in a few members who have started threads on doing the job....then no follow-up or sharing of information.
I'd really appreciate it if you could steer me to a manual reference and/or some threads that actually show me what has to be done.
Ken K.
Old 02-25-2022, 07:22 PM
Hi Ken,
This is the forum for the X300 sedan with the AJ16 inline 6-cylinder engine. Your 1997 XK8 has the AJ26 V8 engine, and the power steering fluid pump is very different, driven by a belt in the conventional manner. The pump is located at the front left side of the engine above the air conditioning compressor (see the arrow in the diagram below):
You can download the Workshop Manual for your car at the link below. However, the 1999 Second Edition has a more detailed and complete procedure for replacing the power steering pump beginning on pdf page 709, so download both manuals for your library:
Jaguar X100 Workshop Manual 1997
Jaguar X100 Workshop Manual 1999
Replacing the pump isn't difficult, but the working position is awkward and getting the high pressure line disconnected and reconnected is fiddly. One way to approach it is to just loosen the high pressure hose fitting while the pump is still mounted, then remove the pump mounting bolts. This will give you some wiggle room for better access to unthread the high-pressure fitting and to access the low-pressure hose clamp.
Also, be careful with your oil dipstick tube once you disconnect its bracket. It's easy to bend, and if you move it too much, you may disturb the O-ring seal at the lower end of the tube which may then leak. Or better, plan on replacing the O-ring.
It's also a good idea to replace the low-pressure hose, since it tends to harden over time and lose its ability to seal at the reservoir and pump ends. In fact, before you commit to replacing the pump, clean the fluid off the low pressure hose and pump and drive the car for a day, then check to be sure the fluid leak is not actually from one or both ends of the low-pressure hose.
Cheers,
Don
The following 5 users liked this post by Don B:
93SB (03-22-2022), motorcarman (02-25-2022), MountainMan (02-25-2022), oldjaglover (01-21-2024), Steve SOMERS (03-01-2022)
Old 02-25-2022, 09:13 PM
cdma's Avatar
Originally Posted by Don B
Hi Ken,
Cheers,
Don
do you have the same manual for the x300. I will also check the download section
Old 02-25-2022, 11:08 PM
Hi Phil,
You can download the X300 Workshop Manuals at the link below. After you unzip the files, click on the README file and follow its instructions. You'll go to the main folder and click on START, which will open up all of the documents with a menu tree on the left side. It's more primitive than the X308 and later manuals, but it's the best we have. As far as I know, Haynes never produced a manual for the X300. Don't forget to check the documents Bob attached in Post #2 of this thread.
Jaguar X300 Workshop Manual Collection
Cheers,
Don
93SB (03-22-2022)
Old 03-01-2022, 09:12 AM
Steve SOMERS's Avatar
bob gauff
Hey Thanks from old git in UK - just starting this job - 1 Mar 22
Old 03-01-2022, 05:26 PM
Nobeel Masri's Avatar
My 97 VP just suffered a PAS pump pinion seal failure. It had been slow leaking for some time already and gave up the ghost yesterday.
I have shopped around for a refurbished pump, but they are thin on the ground and I have heard not so great things about the Cardone refurbs. So I decided re-do the seals myself.
I have removed the pump and am halfway brought cleaning it up before the seal kit arrives.
I will try to post some pics later
Old 03-01-2022, 07:35 PM
John Herbert's Avatar
As mentioned by Don B, there is no Haynes workshop manual for the X300, however there is one for the XJ40.
Many repair instructions are the same for both XJ40 and X300, so the Haynes XJ40 manual can provide additional info in need.
The power steering pump is such an example, see section 10.10 in the attached Haynes manual.
John Herbert
(1196 XJR)
File Type: pdf
The following 3 users liked this post by John Herbert:
Don B (03-01-2022), JudgeGeoff (03-19-2022), motorcarman (03-01-2022)
Old 03-02-2022, 05:35 AM
Thank you for all the info. I don't know how I got to this forum since I was quite specific when I prompted my search for my XK8. But, I am going to continue watching this thread as it is very informative.
Ken
Old 03-03-2022, 04:16 AM
countyjag's Avatar
FWIW, Removing the X300 PAS pump turned out to be much easier than it looked, and the seal replacement kit worked well.
The following 2 users liked this post by countyjag:
Don B (03-03-2022), oldjaglover (01-21-2024)
Old 03-03-2022, 11:54 AM
I just completed the seal refresh on my power steering pump and although I had never done this before, it was a straightforward enough job. I was concerned that I would need the 'Drive Dog Tool' as specified in the 10-04 PAS Pump tool Bulletin, but this only seems necessary if you are switching to a new pump and since I was only replacing the seals it was not needed.
In my case the PAS pump pinion seal had failed
Here is an excellent video on YouTube showing how to replace pump the seals, I recommend watching this before going ahead.
I used the Gates 348416 kit from RockAuto
https://www.rockauto.com/en/moreinfo...t=7407&jsn=412
The procedure is basic enough.
  • Place an oil pan below the PAS pump area
  • Drain the fluid by removing the reservoir and cooler hoses from the pump and seal the hose ends as best you can.
  • Remove the exhaust heat shield for access and visibility.
  • Use a 10mm wrench to loosen the 3 bolts from the pump flange. I also used a long extension and 10mm socket to remove the bolt closest to the engine block. This is a pain to get to but easily done once you get a socket on it
  • The pump can now be removed from the car. I was able to do this from above
  • Get the pump on a workbench (or dining table) with plenty of old newspaper to collect the oil
  • At this point I suggest watching/following the video
  • Remove the 2x 10mm pump flange bolts (you won't be able to remove the flange just yet)
  • Remove the 2x 13mm extension bolts and 2 regular bolts to open the pump
  • Remove the pump vane cover and vane assembly
  • Remove the shaft c-clip, this will release the shaft and the flange
  • Remove all of the seals (all mine were hardened and brittle)
  • Clean the the pump casing as best you can
  • Clean the pump internals to remove any oil dirt or debris
  • Replace the seals from the kit (once again to the video)
  • Reassemble the pump as it came apart (I forgot the shaft c-clip first time round)
  • Make sure the flange hole is pointing down
  • Reinstall the pump to the car making sure to properly align the drive dog to the engine side flange
  • Reconnect the hoses to the pump
  • Fill the reservoir with ATF or PS fluid (DexronIII recommended)
  • At this point I raised the car and went through the fluid bleeding procedure (engine off for step 3)
(From the x300 Haynes service manual)
  1. To bleed the power steering system, begin by checking the power steering fluid level and adding fluid if necessary (see “Weekly checks” or Chapter 1, dependent on system fitted).
  2. Raise and support the front of the vehicle on axle stands.
  3. Turn the steering wheel from lock-to-lock several times and recheck the fluid level.
  4. Start the engine. Turn the steering wheel from lock-to-lock again (three or four times) and recheck the fluid level one more time.
  5. Lower the car to the ground. Run the engine and again turn the wheels from lock to- lock several more times. Set the wheels straight ahead and recheck the fluid level.
  • Once the system has removed any trapped air the steering should now be silent
  • Drop the car back down and go for a test drive
  • Check around the pump, rack and hoses for any leaks
  • Go to the fridge and grab a cold beer and relax.
The following 4 users liked this post by Nobeel Masri:
b1mcp (03-03-2022), Don B (03-03-2022), JudgeGeoff (03-19-2022), motorcarman (03-03-2022)
Old 03-04-2022, 11:15 AM
WOW! Good job!
Old 03-11-2022, 02:06 PM
It has been just over a week since I repaired the PS pump and I was getting a slight vibration and occasional minor whining from the steering. I figured it was air still in the system and would work itself out after a few days which it didn't. I tried bleeding and re-filling the system which seemed to help until the issue came back. After reading up as much as I could about power steering and possible noise and vibration causes, I took another look to see what I could find.
It turns out I had not properly tightened the clamp for the hose on the reservoir (reservoir to pump), which was causing a very slight leak creating an oily mist around the reservoir area. This was enough to allow air into the system and cause the noise and vibration.
The steering is now as perfect as it can be and I look forward to it being trouble free for the foreseeable future. (maybe tempting fate and just cursed it)
I feel like a dumb *** for missing it, but hopefully a lesson learned for us all. Remember to tighten up all of the hoses properly before finishing a job.
The following 3 users liked this post by Nobeel Masri:
Don B (03-11-2022), JudgeGeoff (03-19-2022), oldjaglover (03-13-2022)
Old 03-18-2022, 05:45 PM
Hopefully the last entry in this mini saga.
I suspect age and renewed system pressure took it's toll on the high pressure hose, as it gave out about a week after refreshing the pump seals.
I have read here that it's recommended to change the hoses anyway, but mine had not until now (date stamps are from 1996).
So far I have replaced the reservoir to cooler and high pressure hoses, as well as the pump seal refresh.
I think my system is fully flushed by now, but I have been using Lucas ATF synthetic (DexronIII) fluid.
93SB (03-22-2022), Don B (03-18-2022), JudgeGeoff (03-19-2022)
Old 01-20-2024, 08:19 PM
cdma's Avatar
On my list of to do. Can someone give me a hand and tell me how you get to that far bolt on the power steering pump? The top and side are easy, but the far one, between the engine and the pump, is a bear.
Old 01-20-2024, 08:55 PM
Parker 7's Avatar
Before going through pump removal :
Change the worn out PS fluid to rid it of cavitation noise at the pump
Cut an inch off the hose clamp ends at the bottom of reservoir as common to leak and can be misleading to where the leak is from
Mine had a leak there that went everywhere from the previous owner
Don B (01-21-2024)
Old 01-21-2024, 03:43 PM
Good job on your seals. Your X300 pump looks totally different from the X100 pump.
Quick Reply: Power Steering Pump Removal & Replacement
