Premium sound tweeters and subwoofer
Working on the premium sound system. My subwoofer is blown and missing one of the connections. I'm looking for suggestions on a replacement.
Also want to confirm with premium sound having tweeters in the door handles that there are not ones in the rear. I don't see two rear tweeters per side on the wiring diagram.
Thanks.
Thanks.
The subwoofer is a shallow dimension to not hit the fuel tank under it so a whole subwoofer replacement has to factor this in
There are repair kits to replace the diaphragm surround foam that dry rots away . this is different then the mounting foam
Keep track of your part #s if doing the repair option for the premium speakers that are different then the standard speakers ( Phillips )
There seems to be a mix on what was installed with the tweeters and the wiring may be present even though the tweeters are not
I have the standard system on a SWB 1996 Sovereign and have 4 total tweeters on the dash board and rear parcel shelf
Parker 7 (03-01-2022)
See this tread for the same year and body V12 and the final post # 9
Premium sound system speakers - Jaguar Forums - Jaguar Enthusiasts Forum
someguywithajag (03-04-2022)
burmaz
06-23-2011 02:38 PM
