Pressurised fuel tank
Hi all I have a 1997 XJ6. I have noticed lately that every time I take the fuel cap off there is a big release of air that comes out of the fuel tank. Tonight I took the car to the petrol garage after it had been sat for a week and when I undone the fuel cap it shoot up about 6 inch’s and almost took my eye out. Does anyone know what would be causing this ?
cheers all
cheers all
that for the reply mate. I will and google what this valve is now
There are 2 versions of the EVAP system on the X300 , one with and one without Rochestor valve
Some have plumbed in the valve backwards
There should be a simple blow in tubes test , but probably easier to just replace with fresh part
There is a Delco ( GM ) equivalent # 214552 or 214 - 552
The difference is if you peek under the car without jacking you will have one rectangler box vapor canister on the left just fwd of the rear tire
The other is if you have 2 , one on ech side of the car
See page 60
jagrepair.com/images/Training Guides/801S - 2000.pdf
The second version is electrical that you can check at the ECU connectors
Black 24 and 31 , should not be open or infinite resistance
This electrical valve version may have to do with California emissions or US market as a whole as it's installment is mixed around on production , threw me for a loop and gave me a spot of stumble under my bonnet
See page 60
Amazon.com: ACDelco 214-552 GM Original Equipment Vapor Canister Purge Valve : Automotive
See page 60
See page 60
