programming a remote transmitter fob
Hello sempire.
I have been looking for a keyless remote myself and have yet to obtain one, so I can't vouch for these instructions...but take a look here:
http://www.jagbits.com/reprogram.html
Post back; I'll be curious to see how it goes for you!
Bob
...just saw xjrguy's response after hitting 'post reply' on mine. There you go!
Bob
I have read those, and replaced the batteries. I do get the LED's blinking. The car goes into training mode no problem. I have the right frequency remote, but still when I hit the arm button when programming. i get no beep.
Any other suggestions? Is there a way to confirm the antenna is hooked up?
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Hello sempire.
How to re-program your keyless entry remotes 1990-1996 XJ6s
Bob
Bob
Thanks for this post, really appreciate it! Now that I know it works, I can buy the second remote on eBay that i was looking at; I wanted to be sure that I could reprogram myself before buying it. The dealer I called wanted $150 to do what took me less than 2 minutes thanks to you!
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Sempire, just curious, when you changed the batteries in your remote did you use 2 x CR2016's or a single CR2032?
Reason I am asking, I was in your predicament; my batteries died and I did not have any of the 2016's, but I have a bunch of new 2032's which are essentially the same battery, just twice as thick. Since the voltage was the same, I replaced with a single 2032 instead of the 2 x 2016's; It would not register the remote, and I also was successful in getting it into learning mode. The lights were blinking normally on the remote as well. I went out and got the 2 x 2016's and it worked like a charm.
bob gauff
Jzar
09-27-2015 02:55 PM
zdrapec
09-25-2015 05:49 AM
