Propshaft Alignment
Old 03-09-2015, 01:15 AM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
Thumbs up likewise!
Originally Posted by Don B
I'm grateful for your knowledge and willingness to share it with the rest of us!
Cheers,
Don
I've been all over your photo albums at jag lovers.
They are really handy for visualising what has to happen.
The following 2 users liked this post by plums:
Don B (03-09-2015), MountainMan (03-09-2015)
Old 08-09-2017, 03:03 PM
WayneHWilson's Avatar
Thumbs up Thank You!
Thank You! Am right in the middle of renovating front & rear suspension along with the driveshaft and half shafts on a 1995 XJ6. Now I need to figure out how to align the half shaft units.
Old 03-18-2021, 04:19 PM
nickguy's Avatar
Just wanted to say this thread is still a keeper in 2021. In my case it worked to re-index the differential side of the Jurid coupling. With one of my XJ's being a lifted Cherokee variety the lessons learned from it were also helpful. Mostly the concept that u-joints at the end of a shaft do not need to be straight but they have to have the same angle at each end. Glad that one of the more simple solutions worked. In my case too I will say that lining it up with the plumblines I had to not only move the center bearing full left, but also had to adjust the mounting crossmembers at both the transmission and the center mount. When I get round to replacing components I will definitely get the shaft re-balanced before reinstalling but for now I am happy with the solution and the smooth ride. Reading the TSB from earlier in the thread was also a great idea.
UPDATE!! So while re-indexing improved things it was not perfect. I dropped the center bearing cross member and immediately saw that the center bearing rubber was toast. It is interesting that you cannot really tell until you do this. More to come.
Old 03-18-2021, 11:06 PM
xalty's Avatar
Received 1,061 Likes on 852 Posts
alternative option is not paying attention and just sending it
worked great for me
Highhorse
11-19-2023 07:36 AM
yachtmanbuttson
02-08-2021 10:00 AM
kenhayes247
03-21-2019 04:23 AM
euphonium01
10-29-2018 10:42 PM
nebelfuerst
20
06-09-2014 07:16 AM
Quick Reply: Propshaft Alignment
