Radio/CD Changer question
I have a 1997 XJ6 VDP with non premium sound system. My cd changer went out a few weeks ago it just says no disc even though the magazine is full. I bought one of these off of ebay to try to plug in place of the cd changer and it didn't work Alpine KCM-123B Aux Cable. M-Bus to mini-plug.
Alpine KCM 123B Aux Cable M Bus to Mini Plug Stereo | eBay
My question is there any thing like that for our radios I can buy that will work.
Thank You
Thank You
That would explain it. I guess I will try and fix the cd changer. I thing the arm that grabs the CD's from the magazine is not working.
I took the CD changer out and took it apart to see if I could find a problem with it. I found that the spline gear on the motor that moves the cd from the magazine to the player was striped. So I rigged it to work for know . If my fix breaks I will have to try and find a new motor with a spline gear on it.
All the Jaguar Sedan CD changers from the 80s up to 1997 use the same unit.
Even if you find a damaged one, you could swap parts until it works.
I made a lot of money gathering broken parts from the Jaguar dealer shop and fixing them. I took 2 or 3 broken 'THINGS' and bodged them together to make a good used part and selling them on eBay.
ABS modules, A/C vents, blower motor assys etc.
Look for a broken one and see if you can get it cheap for parts.
bob gauff
bob gauff
FS[LowerAtlantic]: 2007 S-Type $.2 For Sale
captbob73
10-24-2015 05:49 PM
al_roethlisberger
09-09-2015 09:14 PM
