Radio code recovery for older models NLA from dealers?
I know the best place to recover a radio code is the dealer, and the service is free. In making a visit today, both the service adviser and I were surprised to find that the system screen that vehicle data popped up fine by VIN search, but radio code is no longer available. The service adviser said he was accessing Jaguar's on-line global data, so if it does not show up it probably means that data support for older Jaguars has ceased. I was planning to keep the stock radio, but if there is no other way of recovering the code, the only option is to replace it with another stock radio that still works or with a modern head unit.
Received 10,876 Likes
Found this advice on Coventry West.
Jaguar Radio Codes | Coventry West
I shall conduct a carpet sweep to look for marks on the hood or somewhere on the body that might have been left by former technicians who might have worked on the car.
Also tumbled over the following sites while surfing the Internet:
Car Radio Codes
http://radio-codes.webs.com/
suggesting it possible to find the radio codes by emailing the radio model, serial numbers, etc. to <restoredclassic@aol.com> and then paying a fee on-line. Hope it is not a scam.
Car Radio Codes
Doug (03-30-2017)
I've used this site for an X Type code, and after payment I had a code in a few min and it worked.
JAGUAR CAR RADIO CODES - Online Service
Qvhk (03-30-2017)
I finally managed to remove the radio from the console today, with two special findings:
(1) the serial numbers of the unit, which are otherwise needed for online radio code recovery, are illegible due to corrosion of the unit metal case.
(2) fortunately, someone has written the radio code together with the former vehicle registration number on both sides of the case cover.
This XJR had been maintained at the dealer during her first 17 years. (2) probably suggested that the radio had been serviced or repaired more than once before.
I put the radio back and tried to enter the code to test if it still works, but the radio failed to power on. It turned on OK before, and kept asking for "code" in the display. I shall see what I may have disturbed during the process.
Here is an update. Was trying to get the radio back to work. It turned on fine last time but refused to power on again.
It turned out that the removal and re-attachment of the radio a couple of times with the key in the "on" position had resulted in blowing a fuse. The same fuse happened to also govern the opening mechanism of the trunk - both the trunk-opening button on the dash and on the trunk lid failed at the same time. The relevant fuse (15A) is inside the fuse box in the trunk. I successfully opened the trunk by inserting and turning the car key on the mechanical lock on the lid; then found and replaced the fuse, and the radio and trunk-open buttons have all returned to normal.
