Radio Stuck On
Radio Stuck On
I was driving to work this morning, and none of the controls on the radio were responding. I wasn't really bothered as it has been very intermittent since I got the car a month ago, however when I parked up and switched off the car, the radio didn't shut off.
Now I'm concerned it might drain the battery. I believe disconnecting the battery might reset it, but I'm concerned what other effects this might have on the car. Is there a fuse I can pull instead?
Thanks in advance.
Thanks in advance.
thanks, actually i pulled F10 and that did the trick.
i used the fuse guide here, if anyone searches here and needs it
https://www.jaguarforums.com/forum/x...cations-44511/
