Radio turns on when ignition is off and horn not working
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
1995 XJ- VDP ( 2 days ownership only)
Again Claude from Durham NC
Another 2 weird "problems"
Problem 1
When I stop, turn off engine, turn off the radio and lock the door the antenna goes out and the radio starts!
I waited more than 15 seconds but I had to re open the door and manually re shut off the radio.
Not a huge problem but ennoying as it could drain the battery overnight
Problem 2
Only the horn on the left side is working. So I looked at the fuses and haha one of the two fuses was blown. I replaced it but did not cure the problem.
Problem is I cannot see the right side horn (if on the right side of course)
can someone tell me where are the horns located ?
Thank you
Claude
Durhan NC
1995 XJ6 VDP
1991 Audi 100
Problem 1
Problem 2
Thank you
Claude
Durhan NC
1995 XJ6 VDP
1991 Audi 100
BrentGardner
28
04-26-2024 03:08 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
