Rear Bumper
I wonder if anyone can let me know how to ajust the rear bumper for some reason the drivers side of the rear bumber has a gap of about 1/2 to 3/4" the bumper seems tight at the back of the car amd the opposite side is fine too. Is there a way to get it in place and then tighten what ever is loose?
More than likely someone tapped you when parked or you bumped something in reverse. The shock in the back is probably depressed in slightly on one side. It should pull out which may take some force. You may need to remove the bumper, pull the shock out then, and then reattach. You may use a small metal screw as a shear pin to hold the shock in the extended position.
Marque
09-14-2015 11:17 AM
