Rear Diff capacity?
Old 11-08-2013, 10:29 PM
AlbBolivar's Avatar
Default Rear Diff capacity?
Can anyone tell me what the rear diff capacity is on an x300?
Seeing on the Amsoil website, it says it's 2.7 pints which is about 1.35 quarts.
Does that sound right?
Old 11-08-2013, 10:41 PM
Suede's Avatar
1.35qts should be the 'top-up' only amount. Full refill is a bit over 2qts. Here's a full discussion with pics & suggestions: https://www.jaguarforums.com/forum/x...-change-60513/
Old 11-08-2013, 11:15 PM
jvitez's Avatar
I had mine changed while the XJR was at the mechanics for a coolant leak. It used just a bit under 2 qts.
Old 11-09-2013, 02:22 AM
FireCrow's Avatar
whatever you lot say :P From my memory it was 2.1 litres
Old 11-10-2013, 01:00 PM
AlbBolivar's Avatar
Thanks for replies guys!
Now when you guys fill it up, do you guys fill it while its jacked up in the air until the fluid starts to come out of the filler hole?
Old 11-14-2013, 04:51 PM
Fill it flat on the ground until it comes out. If the cat is on an angle it will compromise the level.
H20boy
07-23-2021 09:39 PM
FrickenJag
09-25-2016 08:00 PM
Nigels420G
Mark V - X 420G
09-17-2015 10:29 AM
hafren
09-07-2015 10:30 AM
1100me
09-07-2015 06:26 AM
Quick Reply: Rear Diff capacity?
